Hi
I have the xperia Z since 1 week and I have few problems to play music throught my audio system :
On my samsung home theatre it says ok to play throught samsung HT4500 but when I play music : "unable to connect" so I played trought my Panasonic Viera Tv it plays, but one time a force close ended the transmission, after a reboot it worked but when the screen is off the it stops about 1 minute between 2 titles.
I also use it in my car trough A2dp blutooth (parrot MKI9100) and sometimes it hangs : no more sound, i have to switch off BT and reactivate to work again.
No problem with another phone (Samsung Galaxy S3) on the 3 equipements.
Is it possible to reactivate native android tools that works fine for wifi ?
What about bluetooth ?
Thanks by advance
Are you running on the latest update? (.434)
If not I suggest that you try to update your phone software using PCC, SUS or Bridge for Mac.
If you're already on the latest software you could try to reinstall it using SUS.
