Hi i've got a problem to applying theme..when i apply it the wallpapers on home and lockscreen didn't apply...i already reboot my phone many times but nothing change..please help..thanks
I would suggest that you try to boot your phone into safe mode to see if the problem may be related to any 3rd party app that you have installed in your phone:
You can also try to clear data for the lock screen under settings > apps > all > lock screen > clear data. Restart your phone and try again.
@Alexander wrote:Hi,
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008You can also try to clear data for the lock screen under settings > apps > all > lock screen > clear data. Restart your phone and try again.
nothing happen...i already tried the safe mode and the locksreen clear data..its always black the background on my Home Screen...
Hate sony . dont waste ur time on it any more . as i do
I'm not able to reproduce the problem you are experiencing. You could also try to clear data for Xperia Home under settings > apps > all > Xperia Home > clear data. Restart phone and try again.
If the behavior still persists I suggest that you try to reinstall/repair the phone software using PC Companion:
In PC Companion, press start on Support Zone > Start on Update the phone/tablet software > Press the blue link that says "Repair phone/tablet".
Before repairing the software in your device you may want to backup your information first. Check out this topic for more information on how to:
http://talk.sonymobile.com/t5/FAQ/Backup-amp-Transfer/m-p/407253#U407253
It should be said that, at least for me, this happens with some 3rd party themes. All the default themes apply the lockscreen and wallpapers correctly, it's just for some, just some other 3rd party themes.
5min later edit: Clearing the data from the Homescreen app solved it. Thank you.
