The problem with the update!?
senpoliya
Good day! Dear experts, please help! In advance I apologize for the auto-translation. I'm not very technically oriented, but I'll try to explain the essence of the problem. During the update via USB cable, there is a problem. Now the phone is not included. Appears only SONY, and immediately a message with a triangle on usernam background: "Check your connection and try again." and immediately fade The volume button hold tried, did not help... Computer does not see the phone. Please tell me what to do?
10 REPLIES 10
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
senpoliya
Thank you very much for the quick reply! I'll try the results will be published later.
Don't forget to backup
PC Companion (PCC)
Bridge (for Mac)
senpoliya
The fact of the matter that the copy is not made. Maybe there is some option to save the information?
_alexdon_
If the device doesn't boot,you cannot save anything from internal memory. MicroSD should be intact.
alexdon
senpoliya
All content on the internal storage drive 😞
_alexdon_
I am sorry about that.
alexdon
_alexdon_
Don't you have any backups?
alexdon
senpoliya
Hello. Thank you very much for your advice and help. Phone flawlessly again earned. The most offensive that lost a lot of children's photos ... But now is a science !!! Thanks again.
