Okay, so, as you can all see, the latest user guide for the Xperia Z1 Compact states that the device has an IP rating of 65/68. Previously, we know the ratings were stated to be IP 55/IP 58. Has Sony revised the Xperia Z1 Compact's IP ratings?
Sony, please clear this out. Thank you.
Could you post the source links?
http://www.sonymobile.com/global-en/products/phones/xperia-z1-compact/specifications/#tabs
Durability
*** In compliance with IP55 and IP58 standards, the Xperia™ Z1 Compact is protected against the ingress of dust and water. Provided that all ports and covers are firmly closed, the phone is (i) protected against low pressure jets of water from all practicable directions in compliance with IP55; and/or (ii) can be kept under 1.50 metres of fresh water for up to 30 minutes in compliance with IP58. The phone is not designed to float or work submerged underwater outside the IP55 or IP58 classification range that may lead to your warranty being void.
I had posted a screenshot along with my post. Don't know why it got removed. Anyway, here's the link: http://www-support-downloads.sonymobile.com/d5503/userguide_EN_D5503_4_Android5.0.pdf
Page 135 states it.
I can't see the picture until it gets approved by a moderator
Using your device in wet and dusty conditions To ensure the water resistance of your device, all covers, including the covers for the micro USB port, the SIM card slot and the memory card slot, must be firmly closed. Your smart device is waterproof and dust resistant in compliance with the Ingress Protection (IP) ratings IP65 and IP68, as explained in the table below. To view more specific IP information about your device, go to www.sonymobile.com/global-en/ legal/testresults/ and click on the relevant device name. These specific IP ratings mean that your device is dust resistant and is protected against low pressure water stream as well as against the effects
ok I see it, page 135
Hi Guys,
Thanks for the information, I have passed this information on for review.
Thanks again
