my mobil can't searching the other bluetooth device? and my mobil can't connect to my windows 7 that really weird
if you wants to pair from other device make sure that you have been enabled Bluetooth in visible mode if that dosent work, try to reset your device this helps you. Note : backup your data...
The above will likely answer the Bluetooth problem; however regarding the Windows problem can you please provide some further information? I am looking for information such as what function you are trying to perform between the two devices, are you using PC Companion etc?
my pc get me a message about no searching the driver on my mobil and other bluetooth equipment never been found for bluetooth function that is really before i use htc mobil never happen this kind stuff , how could sony can make this problem?
