HI!
i am in turkye now. i buy this phone (xperia z3) in here but i want to back to usa it will work my phone using other simcart for long time?without any problems?
Thanks.
Ramtin Daemi.
Hi @ramtin
If you buy an unlocked device for any carrier, I suppose that you won´t have any proeblem if you use your device in USA. I´m at disposal for any question.
If a phone is going to work in another country, the network provider that you are going to use needs to use one or more of the networks that the phone supports. More info about supported networks can be found in the whitepaper:
http://www-support-downloads.sonymobile.com/d6603/whitepaper_EN_D6603_D6653_3.pdf
Also note that we do not provide worldwide warranty so it may be limited to a specific region and the repair process may therfore also be affected.
Which Z3 version do you have? which carrier do you want to use your phone with here in the USA?
yes its unlocked in here i take my phone dont need to change imei??
hi its unlocked version single sim and i want use At&t.i just buy simcart put in my phone with out do anything?? or i should do anything else?
its>>D6633
and other things about my phone after recording 4k video my phone backside make very hot!! after 10 or 15min comes out of camera why ??
Hi @ramtin
From your Home screen, please try the following:
1. Tap the Application screen icon.
2. Find and tap Settings -> Apps.
3. Swipe to the All tab.
4. Find and tap on Camera.
5. Tap Force stop -> Clear data.
6. Restart the phone.
