Hi, everytime I wake up my phone I get the following screen displayed. How do I stop this from happening? I have set up my two Xperia tags with the Sony NFC tag software and they work fine but I keep getting this annoying screen which states Unkown tag type and only gives me an option of Done or Delete. I have to select one to get past this screen each time I unlock the phone. There is no tag near the phone when this happens they are in m,y car! Loving the phone apart from this and the yellow/green issues.
Have you hit the "Delete" option and seen if this comes back? If so then I would advise running a software update/repair:
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connectionn steps
