T2 Ultra KitKat and MicroSD
weilies
Dear gurus,
I just get my T2 Ultra and upgraded to latest kitkat.
Am i allow to use microSD 64GB? or only support up to 32GB?
6 REPLIES 6
Hampus
A 64 GB MicroSD-card might work, but we can only guarantee that T2 Ultra is full compatible with a MicroSD-card up to 32 GB.
weilies
Why there is an uncertainty from official support?
Why it "might" work?.what are the reason causing 64GB microSD fail? Whats the error?
Thommo
Genius
Offically it will support up to 32GB - Now the issue is the format - So anything above 32GB has to be in exFAT which won't be supported so to use a 64GB you could try exFAT or use a free program called guiformat on your Pc and force format the card to FAT32 but you will still be limited to the 4GB file size limit
weilies
Thankz and that make more sense for me Slightly_smiling_Face
Even if i.upgraded to.kit kat, do I still.need the guiformat?
Thommo
Genius
I honestly don't know - All I can tell you with certainty is that using guiformat a 64GB card will be ok to use as long as it's in FAT32
Sonic2000
This is a new phone that I got. When I installed a new SanDisk Micro SD Card (32GB) into the phone it recognized it right the way. But, after a little while, the phone will announced it has been removed without un-mounted.  I tried a few times and the results were the same. However, if I plug the phone to the laptop and Sony PC Companies could see the card without any issue.
I.e. the card was physically connected.
Please advise if there were anything I could do to fix this, thanks.
