swipe screen problem
XperiaE1bre
i have a problem with lock screen
I cant sec on swipe or none, its say disable by administrator, encryption policy or credential storage
i tried to clear credentials, but dont help
in device administrators i disable android device menager, but still same
some solution?
its happend one week, i instal v4.4.2 android, since than
2 REPLIES 2
Thommo
Genius
Try performing a system repair as this will often fix issues after an upgrade - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
tingu
hii
i hve a sony xperia e1 D2005  whc i buyed last 6 monts ago n updated it to kitkat version after update "none and swipe" option is not working n it is disabled i tryed repair phone and contacted autorised sony service center in bangalore  but still it is not yet solved.  service center guys said i have to sign out Gmail  account  and try it. but still "none and swipe" is disabled. Please solve my issue.
