Strange problem
madelajna
Strange problem
I have very strange problem with my Xperia. When I make phone calls the screen locks up and I can't  do anything. I have to remove battery and turn it on again. Can I fix it myself or should I take It to the service?
Sorry for my english by the way Face_with_stuck-out_Tongue
7 REPLIES 7
profile.country.RO.title
_alexdon_
Can you check if the same occurs in safe mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
alexdon
madelajna
I checked. The same occurs in safe mode.
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
Don't forget to backup
madelajna
Allright. I'll try.
madelajna
I did it and it's still the same. Any other ideas?
_alexdon_
You should take it to a sony service:
alexdon
