Hi
My x8 will only charge when the cable is plugged into an Iphone USB adapter.
I thought the mains adapter block had died. So I bought a new one. It didnt work.
So I bought a thrid party adapter. Still didnt work.
So I bought a brasnd new sony charger cable and mains block.Still nothing.
I plug the cable into an Iphone block and it charges fine.
any thoughts as to why? Or do I now need to buy an iphone?
http://ww.sonymobile.com/gb/tools/update-service/ Strange problem indeed! It may be a software related issue, so I suggest running a software update/repair and see if that solves the problem.
Also, if you have the option to switch USB charging off, try it and see if that enables mains charging.
Hope this helps.
Wise thing to try what Dr_Chris recommends above.
