hi
when I start it up my sony Go, it loops forever..... never finishing startup....
it can also not be recognized again by my pc when I turn it off / on through forced shutdown....
What can I do ?
J.
You need to perform a system repair however this will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
