stamina mode?
xperiaz2
stamina mode?
Hi, i got the xperia z recently. Have noticed that at times the stamina mode doesnt work properly. When you toggle between it the battery life doesnt change. I then have to reset the phone post which it works fine. This has happened 3 times in the last 5 days.Does anyone know how to fix?
33 REPLIES 33
could you elaborate? do you mean that it doesn't turn on ?
xperiaz2
No. I mean i can switch it on & off however when i switch it on, it makes no difference to the estimated battery time left. However if i master reset the phone, then it turns back to normal which means - It does show a difference in the battery time when i switch it on & vice versa.
Aky1
Well everyone is facing the same problem. Right now there isn't any permanent solution for same. Even I tried reseting my phone twice, after which stamina mode will work fine for few days and same problem will be back. Well I can't afford to loose my data( reinstalling all apps, even though I take backup) and reseting my phone everytime.
Hope Sony will solve this problem in next update. Till then bear with it. Neutral_Face
that's odd it works for me, it changes from 2days to 4days on standby, which build number do you have?
@aky have you repaired your phone with PCC or SUS?
xperiaz2
i havent taken my phone to repair anywhere but i plan to this saturday as on a full charge now it hardly shows a standby time of 20 hrs which is scary!
xperiaz2
Yes even i lost my data thrice doing a master reset. However if you are facing the same issue how do you manage the battery life. It just gives me 20 hrs of standby time on a full charge.
xperiaz2
You are lucky that it works fine for you, when i reset my phone i also have no problems for at least a day but then it switches back to the same problem
Aky1
Yeah I did SUS but like I mentioned earlier, stamina mode was working fine for few days after reseting and SUS (here I tried both solution).
