STAMINA mode stuck on
Chrisso
Hi folks,
When my z2 reaches 30% battery remaining my wifi turns off, screen brightness turns down and auto sync gets turned off. I have zero power options enabled but this still happens. I turned it off originally because when the phone entered stamina mode it was fine while it was low on power but when you recharge the phone no features would auto enable. So I found myself missing crucial work emails and blowing through my data limit because wifi wouldn't turn back on.
Can anyone help me solve either of these?
Thanks
Tags (1)
6 REPLIES 6
Or repair your phone with PC Companion (PCC)
http://support.sonymobile.com/us/tools/pc-companion/
Chrisso
Thanks very much guys. I'll try the safemode first, let it run under 20% and see if it enteres STAMINA mode still. If it doesn't then ill try the restore and delete some unneeded apps.
Keep us updated
Chrisso
So I ran my phone from 30% down to 10% while in safemode (took a fair bit of work chewing all that battery with nothing running!) and it did not turn on STAMINA mode. Didnt adjust my volume, disable auto-sync, change my brightness or disable my WIFI.  So I've just now wiped my phone and am in the process of making it usable again with just using the bare essentials, although google is not making it easy as it's reinstalling all the old apps again.  Just uninstalling as fast as I can Slightly_smiling_Face  Hopefully this pans out!
Keep us updated
