Stamina Mode - Draining battery
lajithpv
I have put my phone in stamina mode to increase the battery life but I see it not lasting much than in normal mode. I do get 16 hours in nomral mode but with stamina mode I get only less than 12 hours of life. I have whatsapp added as 'Apps in Standby' list.
I noticed Android OS is taking 59% where it take only 3% in normal mode. Please find the attached screenshot.
Thanks,
Lajith
2 REPLIES 2
profile.country.RO.title
_alexdon_
You should also add the screenshot.I would suggest you try to use the phone in safe mode for some time:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
alexdon
jackxperiaP
android os should not take battery above 10%-15% .. if your device takes more than that then jus switch off the device and restart after few mins .. whatever heavy apps u use, android os should not go beyond 15% of battery use.. from my knowledge when it goes above 20% upto sometimes till 80% then battery begins to drain like **bleep**.. stamina mode and battery drain has no connections at all.. go to settings/apps/all/eco mode controller and clear data and restart the device, also restart the device whenever android os goes above 15% .. i think this ll be useful and i know this from my own experience in my xperia p ..
