To remove system apps you will need to root your device but in doing so may void your warranty - All you can do is move music etc to an SD card and then remove from your phones internal memory
If you still want to root your phone
Hi Ese,
Discussion Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines
You can also Disable some apps that you do not use, disabling apps will also uninstall any updates that may have downloaded directly for the app, this will help clear up some space.
clear spotify cache and also create a whatsapp backup and move it to your SD card then clear Whatsapp data, keep in mind that doing this will delete all conversations but they will be stored on the SD card.
