hi
here a tutor to your SP and its problems
1.when we get updates?
look here
http://talk.sonymobile.com/t5/Xperia-SP/When-are-we-getting-the-latest-update/m-p/496141#M7952
please dont make another topic and ask very same question
2.how to update my phone
a.use PCC
b.use SUS
c.bridge for mac
d.use OTA(it may not avalaible for you)
3.update is unleashed but for me says that i have latest update
wait..it take time to update hit you device(depand on country and network provider)
4.SUS\PCC wont find my phone
you are using win8\8.1 run them under compatibility mode with win7 X86
5.after update my phone turned off and wont turn on again\a problem appeard and update proccess didnt complete and my phone died
connect your phone to wall charger..open back cover..push and hold OFF button with tip of pen until phone vibrate 3-times..let to charge for 3hours after that perform a software repair via SUS
6.what about kitkat?
no one knows..keep an eye on SONY blog or ask sony
7.i have updated my phone to 4.3 (0.206\1.201) and my phone gets laggy-slow-minilag-etc..
a.first after update perform factory reset(better to do it after any update)
b.if no avail the use software repair via SUS
c.disable chrome,remove your exchange account
8.i backed up my phone but now i cant restore them
if you backed up your phone on 4.1.2 you cant restore it on 4.3 better to dont use phone to backup..use PCC also backup your media files manually
9.none of above suggestions didnt work,i want to downgrade
here..beware that may void your waranty
http://talk.sonymobile.com/t5/Xperia-Z-ZL-ZR/How-to-manually-update-downgrade-root-2013-Xperias/m-p/... http://www.xperiablog.net/2012/03/26/debrand-your-xperia-s-tutorial/
https://mega.co.nz/#!4B4y0DIL!qxFhQ9xtBUNK1GL7Ih2xB0QdGd0xgtZIx96fRtRVpmc
10.how to take screen shots?and where is developer options?
push volume down + power button at same time and hold goto setting>about phone>tap 7-8times on build number
11.camera pics are blury or noisy
if its apear on superior mode then try to take photo on manuall you can adjust ISO,HDR,WB,Exposed value you will find out how to use them propely in any conditions
12.how to change superior mode picture size?
you can't
13.walkman sound get lower and higher,also bass boot will reduce vocal
its a harware limit or better say its a some kind of normalizer you cant do anything about that( i know its very annoying)
14.everything got duplicated on SD card
copy one of each file\folder to your pc..format SD copy back your data to SD
15.how to move apps to SD
you can't
16.when phone is charging screen wont show up
its a bug..no sollution till now
17.have a sound problem..sounds get too low,else
goto setting>apps>all>find smart connect and sound enhancmet cleac cache and data force stop and reboot phone
18.when phone is in flat surface touch wont respond \ while charging phone touch not respond
seems in new SW(1.201) problem gets solved
19.i push power button but screen will get gray and wont show up
its a bug in latest 4.1.2..problem soved in 4.3
20.im on UK and didnt get update since others get it
there is somthing wrong with UK that they will get updates much after others in world get it just wait
21.a game is crash..this game is not a big deal but crash
all games shal not play in any phone..even a small game check here for list of some games work or wont work http://talk.sonymobile.com/t5/Xperia-SP/Xperia-SP-game-dicussion-update-regulary-check-first-post/m-...
22.i want to set illumation bar as i want
use 3rd party apps,light flow,illumation bar are good apps
23.walkman lock screen widget wont show up when i listen to music
uninstall smart key app
24.i havn't switch languages in keybord
you will not get that bottun if you chosed languagages like (english-italian-germany-etc) phone try to determine wich language you are typing and give suggestions
25.an app acting wierd\crash\force close\wont respond it worked before
goto setting>apps>all>find that app clear cache and data force stop
26.i have low WI-FI range
that problem fixed in 4.3
27.bravia engine 2 doesnt work for album
yes..it wont work on 4.3 and no soluttion till now
28.adapte to ligh condition dosnt work
use 3rdparty apps
29.top part of screen wont respond
try software repair it may help stop by a repair center
30.i have screen flickering all the time
a.reduce backlight\turn off adapted to light comdition(in some cases it solved problem)
b.downgrade to 4.1.2 (see 9)
and see here
31.
see nubmer 30 (just add it)
