Does your phone has a protective case or film that might be blocking the proximity sensor?
If you don't have it then you haven't installed it as it's for use with headset mainly however try Settings then apps then tap the 3 dots and then tap on reset app preferences then reboot and test however this will reset all setting or changes you have made like ringtone etc back to default
