Able to click Picture but its not getting saved - tried change SD Card & Internal memory. but both are not working. somebody pls suggest what to do. Tried reset phone still facing the same.
Sreekanth
My Contact Number:
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
