EDIT: Just to be sure, did you perform the full test while it was in safe mode? As in use your device normally from 100% to 10% while in safe mode?
You can try running a software repair, but I think you will have to have the unit assessed by a repair agent. If the software repair does not work, contact your local support team to arrange a repair.
no, not from 100% to 10% in safe mode, while try that next
I attach the screen shots requested.
@a00r, Try the software repair, but if that doesn't help you might have a faulty battery, and will have to contact your local support team for a repair.
@Rnaidusa, As uliwooly said your phone is constantly awake, which would contribute to the large battery drain. It is very likely an app that is keeping your phone awake. Try the same tests in safe mode.
