Sony Xperia z2 camera
Alperken
I have Sony Xperia z2 and camera to demolish suddenly. I don't understand anything because nothing happend different about the phone. Now I can't using camera there is a just black screen. Please help me about that.
Thommo
Genius
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
if that fails then I'm sorry to hear this but you would need to either return your device to the place of purchase or contact Xperia care and have your device inspected http://www.sonymobile.com/global-en/support/contact-us/
