Recommendation engine extention
Nivad
When ever I lock and unlock my phone, it says "sorry recommendation engine extention has stopped" or something like that. I'm worried. I'm using a Sony Xperia Z1. Please give me some good news.
Thank you for reading.
5 REPLIES 5
Thommo
Genius
This is a new one on me and have never heard of it - My only advice would be to perform a system repair
Performing a system repair using PC Companion will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Nivad
Would doing a regular factory reset (through my phone) fix it? I'll send a snap of the message. Once it appears again. If possible
Thommo
Genius
It may but I find a system repair to be the best option
Nivad
Okay. Thank you for your opinion. Will try it out report back when done.
Nivad
And*
