sony xperia z1 not starting after random shutdown?
Weirdnotificati
i was playing on my phone on a game and when i started the game the phone shut down randoly so when i got in i put it on charge (which normally fixes it as it has happened befour) it still wont turn on the screen remains balck and the charging light does disply when onj charge i seen another past saying to hold down the power and vol up button and when i do my phone vibrates and the charging light flashes. is my phone broke or have i done something stupid? Thanks for the help.
17 REPLIES 17
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
alexdon
Weirdnotificati
Thanks ill try it...
_alexdon_
Keep us updated.
alexdon
Weirdnotificati
the pc companion could not connect to my phone. i have tried several times and it failed each time.
_alexdon_
Make sure the device is turned off. Do not connect until you are prompted.
alexdon
Weirdnotificati
how do i know if it is turned off as there is no dispaly the only thing i see is he charging light...?
_alexdon_
Force shutdown by pressing power button and volume up at the same time.
alexdon
Weirdnotificati
no matter how many times i hold it in and my computer makes the connect/disconnect sound it wont work?
_alexdon_
Did you keep volume down pressed when connecting?
alexdon
