how did make the update thruogh the phone or the pc ?
As Phy said, all these problems will vanish if you do a clean installation, that can be done via PC Companion Phone repair.
Also,see if in this topic you find useful information:
/t5/Xperia-Z1-Compact/Lollipop-update-is-a-mixed-bag/m-p/968018#U968018
Quite. Just did a full reset on mine (from the menu) followed by a restore; which hasn't restored anything useful. And it's still heating up and has used 10% of battery in about ten minutes. Makes the phone unusable. Shame, I was very happy with it. No chance of another Sony phone then.
And people suggest using PC companion to do firmware updates? It can't even do a simple backup and restore without crashing repeatedly and causing the phone to reboot.
I'm not happy.
Dom.
Yes, PC Companion is far way better solution than factory reset, because it formats your internal memory and installs a clean copy of latest firmware. While the reset from settings menu will not format, there's a big possibility that issues will stay the same. I'd suggest that you do a PC Companion phone repair:
Open PC companion -> Support zone -> Phone/tablet software update -> Repair my phone/tablet (blue link style). Follow the steps given, do not connect your phone until prompted to press volume down while plugging USB cable.
Just update with Pcc as suggested, three times already, if pcc crashes then try a different computer
