Sony Xperia Z charging problem
Asad1050
My Xperia Z is successfully charging from my laptop but it does not charge from wall charger, infact not from its original charger.
13 REPLIES 13
profile.country.RO.title
_alexdon_
Are you using a different cable for the laptop?
alexdon
Asad1050
No, I'm using same cable for Leptop
Tags (1)
_alexdon_
Maybe it is the socket with problems.
alexdon
Asad1050
Then what I do to remove this problem.
_alexdon_
You have to get someone to repair the socket.Did you try other device in the socket?
alexdon
Asad1050
No, I have not tried another device on this socket.
Is there any chance that the socket will making problem.
Asad1050
Do you know any one having same problem with his Xperia Z
Tags (1)
_alexdon_
There are cases similar,where the socket could be the culprit or the phone or the cable.Try another device at the socket.
alexdon
Asad1050
Other device like??
