HI All,
i dropped my xperia tipo single sim mobile on the floor. i took it and assembled thesame but noe it s not detecting my sim card. the sim card is getting detected in all other mobiles. my mob is still within warranty period. is there a away i can get replacement for a new mobile.
Hi, contact your local Service Centre.
Don't forget to mark correct answer as Accepted Solution.
If you find the post helpful, press Kudos.
Thanks for th equick reply, I just want to know weather getting replacement is possible or can it be repaired. the sim crd slot is bit shaky condition
You need to check with your local Service Centre. They will access the damage and advise you.
Take note that warranty does not cover failure due to accident.
