Hi there, Can you tell me what happened with this issue REGARDING THE bLUETOOTH ACTIVATION CAUSING A REBOOT LOOP ? I have just had the same thing happen to my xperia neo 😞 Also I cant connected to the PC Companion because the phone is stuck in a loop and driving the PC crazy going on/off/on/off all the time... Does anyone have the solution ? This issue seems to have a very long history but I don't see any final fix. 😞 Please help anyone. TonyN
Try performing a system repair as this will often fix issues - This will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
