Cpecifications for E6833 says that this device has a screen with resolution of 4K 2160 x 3840 pixels (~ 801 PPI pixel density). However,
DisplayMetrics metrics = new DisplayMetrics();
getWindowManager().getDefaultDisplay().getMetrics(metrics);
metrics.density.Dpi returns a value DENSITY_XXHIGH corresponding to HD display, instead of DENSITY_XXXHIGH, corresponding to 4K display. Why so?
Hi. May be. But you mean that some Sony-applications can use 4K resolution. Meanwhile I want programmatically request physical resolution of 4K display. What for, this 4k display, if it can be used only by Sony applications? What can I do to verify that it is 4K? Maybe it's just words and a marketing ploy to be able to raise the price of the device. And real resolution - FullHD, because this can not be determined visually.
4K all the time will drain your battery like crazy and will heat up your phone, not to mention that it's an overkill, what would you want 4K resolution when you are reading an article or just looking at the regular icons on the homescreen?
But you could try this instead
http://forum.xda-developers.com/z5-premium/general/changing-resolution-default-to-2k-root-t3282319
@edmonddantes1829 wrote:
If I understand you correctly, you want the phone's resolution to always be in 4K? Unfortunately, even though that would be awesome, I don't think that's possible unless you root the phone. Overall, I believe Sony just wanted to be the first manufactor to be able to say, "We have the first phone with a" 4K display". The problem was that, unlike the G3 that had the world's first QHD display (I think?)the G3actually used it all the time, Sony didn't really say that the phone only used it for certain apps. I actually find it ironic that Sony was the first one who put a 4K display on a phone because when the Z3 came out, I read an article that they didn't put a QHD display on it because at that screen size, you couldn't tell the difference.
No, I don't want to set my Z5 display to full time 4K mode. I am developer, I just want to get ABILITY to set my Z5 display to 4K mode for applications that I can create.
@uliwooly wrote:4K all the time will drain your battery like crazy and will heat up your phone, not to mention that it's an overkill, what would you want 4K resolution when you are reading an article or just looking at the regular icons on the homescreen?
I am developer, how can I detect that 4K-display insrtalled to device? Yes, I understand that 4K will drain battery...
Check the XDA forum and also this
http://developer.sonymobile.com/2011/09/28/sony-ericsson-supports-independent-developers/
