I bought Sony Xperia E on November 4th and this mobile performs good in all ways .
It works good with Whatsapp, Wechat,Bbm,Facebook and its messenger without any lags . but lags when I install Viber Because you it has only 512 mb of ram so we cannot except much out of it .
But after I Updated my Phone to the latest Firmware (11.3.A.2.13) it started to lag ..
Whenever I locked my screen and open it after sometime maybe an hour it would lag or gets stuck at the homescreen for more than a minute ..it was too bad for me .. i searched throughout the internet for solutions for this problem and all of them pointed for rooting the phone !!! which i dont like because it voids the warranty . but it worked well in safe mode . I called up the Sony Service centre they told me to reinstall the phone software which would fix the problem.. if it is not corrected they told that it may be a hardware problem ...
tried reinstalling the software and installed all my apps which is mentioned above and again the phone started to hang after the locking the phone.
after somedays after going to 3 service centres i came to know that the new update (11.3.A.2.13) takes a bit of extra ram maybe a 40 mb which effects the apps to run properly . To fix this lagging problem i reinstalled the phone software and Installed Specific apps and moved the movable apps to internal storage ( NOTE : you can install many apps as you want but some apps use a lot of ram which slows down your device ....) i removed bbm which uses about 50 mb of ram minimum and i used only Apps which use low amount of ram like (Whatsapp , wechat , Fb messemger ) and additionally i am using Instagram Skydrive and Skype which i logout frequently so that is not a problem and games such as Angry birds starwars , space , Temple Run 1,2 and fruit Ninja and 1 big ram **bleep** appp Facebook !!! by using these app i didnt get any lag for the past 10 days now i am happy with it the solution is to remve some of the big ram users app Like ( BBM,VIBER etc) this will give space for the system UI and the Launcher to work properly which makes your phone rum properly If you want BBm or Viber you may have to remove other apps like Wechat , facebook then you can install them . its not a problem with your phone .its the problem with app which uses a lot of ram . to Check out which app uses a lot of RAm got to settings --- apps -- slide to memory and if you want and detailed list install Clean Master app.. Cheers !!!!:smileyhappy
Yeah send me the link , I can unlock the bootloader through Sony website though
its easy from there .
give me the link?
Try to do Data Factory Reset.It may help you.My Xperia E dual runs smoothly after factory reset...
hii sirmy sony xperia e3 dual got hanged everytime it gets hanged i have given it for software update 2 days before everytime it gets hanged so please give me a solution to this problem
