I'm using the MW1 with Xperia S but there are so many problems that I have faced :smileysad:.
The accessory freezes on the following:
Transfer Files to SD while connected through the USB cable.
(MP3)Play Music From SD while the device is paired.
Other errors:
Radio not functionaing well while paired
Bad Sound Quality sometimes when Playing Music through Bluetooth.
Volume increase on bluetooth call only not Media.
I've noticed that these errors occur when the device is paired with the phone, but mp3 & radio work
smoothly when it is not paired.
Also why isnt the TrackID working??
Message was edited by: moeillo
I'm using one myself and I think it's the best thing since MW600. You obviously have some kind of problem with your MW1 so I suggest that you contact your retailer/local support team to get it examined and fixed.
I use this headset and also my colleague.
We have a stability problem with this item.
When it works is great! but from time to time
this headset is unstable an stop working.
When will next firmware update be available?
my current firmware is 0.0.A.4.9
