Dear Mr. Javier,
Thank you for contacting the Sony Xperia™ support centre.
The device may experience the following scenarios after you have updated it, or it fails to update:
The device is constantly restarting after a software update.
The device is constantly restarting after a software update failed midway into the process
The device shows a yellow warning triangle after the update and it won't go away from the screen.
The device turns on and the Sony/Sony Ericsson Logo/Xperia™ logo appears. The device then reboots and starts over.
Solution/Instruction
The software update was not successfully completed. This can happen if the update was started with a device that was not charged to at least 80%, or if the USB cable is disconnected from the device before the update is finished.
Perform a software repair using PC Companion or Sony Bridge for Mac to remedy the problem
Press and hold down both the volume up key and the power key for 10 seconds. After the notification light flashes three times, release the keys. The device turns off automatically. After the device is turned off, restart your device by pressing the power key.
If, while you try a system repair, the computer blocks the installation of the repair / update service, download, install If, while you try a system repair, the computer blocks the installation of the repair / update service, download, install
To perform software with update service:
Download and install PC Companion from
www.sonymobile.com/us/tools/pc-companion/ on your Windows® computer, if it is not already installed.
Turn off the phone and disconnect it from the computer. Note! No matter what the program says, do not connect the phone until you have completed step 11.
Computer: Open the PC Companion application.
Select Start under Support Zone.
Select device Software Update and Start.
Could not find phone appears. Select Repair phone and Connect.
You are warned about the loss of your personal data twice. If you acknowledge that continuing will overwrite all data select continue.
Tick the box to confirm that you have understood that all personal data will be lost. Then click Next. The application prepares for the update and if necessary downloads required data from the web.
Select your phone model manually and then click next.
Depending on the model selected, you are asked to perform a few steps for the update for PC Companion to be able to update the phone software. Do not connect the phone yet! Note! At this point the phone must be off and disconnected from the computer.
Connect the USB cable to the computer, not to the phone.
In Xperia™: While pressing and holding down the indicated button, connect the USB cable to the Xperia™ device, and keep holding and pressing down the indicated button until The update of your device has started... appears (in some cases Installing drivers appears first).
If you failed to follow the steps correctly the phone will turn on, and Proceed with the following steps, slide down the notification bar appear. If this happens, disconnect the phone from the cable, turn it off and repeat from step 12.
Follow the instructions on the screen. When the repair is finished, disconnect the device and then start the device again.
Select Next. If the repair was successful, the message the device has been successfully updated appears. Select Finish.
If the Xperia™ device becomes unresponsive during the software repair, reset the device using a forced restart (hard reset).Then try running the software repair again.
If the problem still remains, contact your local Sony Mobile authorized service center for further diagnosis.
Note: Don't forget to back up all data on the phone before handing over the phone to the service center.
For the latest news, information and product support about Sony Xperia™ please visit
www.sonymobile.com . Or you may contact our customer service line and support in Colombia at 01800-0966-080.
Kind Regards,
Leonardo Meneses Ramos
Sony Xperia™ Customer Services.
Sony don't want to admit than the trouble is ofrece the 4.4 Kit Kat software
