If you want to find out about your warranty,contact sony:
About the keyboard,do you have some task killers or antivirus?
Do you have a protective case or film?
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
If the above does not help,you need to stop by a sony service.
Keep us updated.
Don't forget to backup
