My ten-day z2's rear camera stopped working how can I solve this problem?
Do you get any errors?
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
PCC its a good idea, but don't forget to backup
