sony experia go problem pls help
kaduday17
My daughter jas sony experia go the unit was given by a friend and havent use the unit for quite sometime and she has given it to me so i let my daughter use it my problem is some portions in its screen doesnt respond example the letters on the right side when we touch it it doesnt type also the delete (x) also isnt working sometimes the lower part also when we use different keyboard the ? doesnt respond also pls help what shall we do
2 REPLIES 2
Thommo
Genius
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
SophiaW
Enthusiast
Hi kaduday17, welcome to the community!
If the software repair doesn't help, which I do hope it does, I would advise contacting Sony Xperia Customer Care in your region - just click the link in my signature for contact details.
