Sony Ericsson Elm Bluetooth problem?
Hi, I bought a sony ericcson elm yesterday and I didn't have any problems with it. The bluetooth worked just fine, I even sent some of my files from my old cellphone to my new elm via bluetooth, but later on the same day I couldn't use the bluetooth. I can't turn it on nor turn it off, the option is just grayed out and when I select it it says "Currently Unavailable". Same with the "phone name" option. I don't know if it matters, but I've also had problems with wi-fi at the same time the bluetooth problem started. One day later and the problem still persists! Please help!
I too had flakey bluetooth, particularly if the connection dropped during a sync. I could thenselect the Bluetooth on/off option, but could not return to the main menu. Had to remove the battery to clear the problem, as not even the powe button would work.
I upgraded the software, and that has fixed the problem.
Regards
