While updating custom ROM, I forgot to wipe data and follow instructuions appropriately. Hence, Sony Ericsson Arc S LT18i phone stuck displaying sony logo and not booting up. Please help.
Additional Information:
a) Flashtool is not identifying the flash (back) key
b) Also tried repairing the phone, sony pc companion is displaying software not available message
When your phone boots, do you see the blue led ?
If yes, means you still have the recovery on it.
If that's the case then download some other rom and flash it again.
In case the above is not true, you're left with no other opton but to use flashtool.
Make sure your phone is off while you connect it ( take the battery out and then insert it , then do no switch it on but connect to flashtool ) and you have the proper flashmode drivers installed.
C;/ drive > flashtool > drivers > install > mark flashmode drivers and xperia arc s drivers > install.
how to fix my sony xperia arc s... stuck in sony logo everytime i turn it on....?
And my sont xperia arc s cant detect using usb.....its only charging when i connect to pc
