Sony Arc is stuck on safe mode. How do I get out of safe mode?
I have factory reseted my phone as well as updated my phone to the most recent update. but it is still on safe mode. How can i exit safe mode?
20 REPLIES 20
yes i did switch it off, and i have factory reseted it, and it still boots up in safe mode
ive tried everything i could think of, i dont know what the problem is
Sam
Legend
Legend
I’m going to ask a weird question, do you happen to have a third party case or screen protector on your phone?
What are your thoughts about this forum?
Let us know by doing this short survey: http://surveys.opinion-8.com/SE/SF/en
gwhispererz
If nothing works, bring it to the nearest SE Service Centre, they should be able to assist you.
Hi Sam ,
I am Facing the same kind of issue and yes I have got my Phone laminated . I am facing this issue after ICS update . Kindly let me know what to do
vonis26
My phone went into safe mode. I removed the battery and sim card aswell as SD card for a few hours and when i turned it on later it was back to normal. I hope this helps someone
chacin
I have an Xperia ARC lt15, I´m so desperate don´t know what to do. I also tried to rerpair it from the pc companion and it prepares the pc , the phone turn off with the led turn on in blue...HELP !!!! I have importants apps that I can´t loose...
Gildor
I had the same problem.....what I did was to power off, remove the battery, remove the sim card and then put back in and start up..it works for me. Hope this helps.
danica81
please how do i get out of safe mode in my mobile help thanks.
ditj
I already factory reset, but still safe mode. Plis help
