SOLUTION for the hard camera button problem!
savante
I don't know how strong was the Sony testers but my hands were shaking while pressing the camera button. Actually it is a very sloppy solution as it is simple but it works %100. Now I can just press my finger lightly against the camera button like the way it should be in the first place.
I thought the problem was the button itself was to deep and the button pusher on the cover was too short to press it in. So I just teared a really small piece of paper from the newspaper (it should be newspaper because the paper is soft) and fold it to be 3 levels (you can try and see how many folds suits you the best) and put it right in between the button and the button pusher on the backside cover.  Put the cover on carefully not to dislocate the paper and you got a proper camera button. The paper you use should be really thin, don't try to put a pile of paper and break your cover. Just a tiny piece of paper to hardly cover the button will be enough. If you don't here the clicking sound when you press the button to first level to focus then the paper is too thick.
Trubo_XL
LOL! "Technically" solved! XD
