my headset flap on xperia z in automatically comin out .if i close the flap its closed for a while and again the flap comes out automatically . how to fix this issue........... is there any replacement of flaps or replacement of xperia z full pannel????
I believe you can purchase here, I think these flaps will be a best seller :smileygrin:
its given as out of stock
contact them by email and see when it will be in stock - don't forget this is a very new device
In the meantime keep it away from water
as you would any other mobile phone
One of the reasons I bought the chaging dock was because I didn't like opening the usb cover multiple times per day as it wouldn't last and eventually lose it's water seal
I think it's good that there is a source for these parts and not too expensive - they even sell the LCD assembly which is good
i should buy tat flap and paste it wit tat white colour flap inside ah?
not sure what you mean but yes just buy the new flap and keep the phone away from water in the mean time - you may not be able to fit the the little tie that holds it when open - not sure
you need to see when you get it if the old one pulls out with gentle force and you can push the new one in - never done it
Just briefly skimmed this thread....hmm if the flaps were to get damaged...I dunno how you'd replace them tbh, those white/translucent attachements would have to be secured pretty tightly no? =/ Wouldnt want to damage the phone.
right - it is obviously possible to replace them since you can order them - I know how I would do it but it would be a good idea for anyone ordering to ask for possible fitting options from the supplier - that's what I would do
yep couldn't agree more geoffh. I wouldn't dare to install them myself without knowing I'm doing it correctly basically because if you don't, and you wet that phone...bye bye $$ lol
the only issue is how to attach the plastic tether
