Has anyone had an issue with the power button all of sudden no longer working to turn device on to access alerts and what not on the watch? It was working just fine then suddenly yesterday would no longer recognize when I pushed the power button. Tried reseting several times and same result.
Check your screen is fully seated in the frame - If you have the issue of a lifting screen then this will cause the power button on the frame and the actual button on the watch to be out of alignment thus making the big silver power button non working
