Hoping someone can help.... I got my smartband yesterday and was really pumped for the vibrating smart alarm feature. I have gone into the smart connect app, then to smartband and have turned on smart wake up with a time of 06:30-07:00.
When i went to bed i put the smartband into night mode, however this morning i did not recieve any vibrating alarm to wake me up.... i was woken up by my normal alarm which i had said to 5 past 7 just in case.
have i missed something that i should of done to get this feature to work?
many thanks
yeah my alarm is now working but this morning (saturday) did the same thing as above...... woke me up on my day off..... really annoying
If I can remember correctly, according to the online manual, Smart wake up will be activated automatically if during (in your case) the time of 6:30 - 7:00 am. you have a light sleep. If you were happen to be in a deep sleep, the function won't be activated as it would interupt your sleep. Therefore, the regular alarm clock will be activated instead. :smileysmileywink:
no it will always wake you up at the latest time regardless of your sleep...... so in my case, even if I am still in deep sleep the alarm is supposed to go off at 7:00am
The Smart Alarm only works if your SmartBand is connected to your phone. Check that you band has not disconnected itself in the middle of the night .. if it has .. then your alarm will go bonkers!
I got the same problem and think it is bug in the smartband software which Sony should fix it asap.
