Smart Tag Questions
CiderPhil
Smart Tag Questions
The idea of Smart Tags seems good but I am struggling with a couple of issues:
When I get into the car I want to turn on GPS but that option doesn't seem to exist in the Smart Connect setup list.Similarly, when I get home I want to turn GPS off as there is no point in having GPS indoors.
At the bottom of the setup list there is an option titled AT THE END. I don't understand what this means. Can someone explain?
Thanks, Phil
2 REPLIES 2
that option used to work with the Xperia S before ICS, but it doesn't seem to be available for some odd reason.
http://talk.sonymobile.com/message/244522#244522
Mr_Lu
if you assigned an application as trigger which request to enable GPS for example Navigator, then the phone will prompt you whether enable GPS when app starts.  I think it is enough and from power saving point of view, it is good.
At the end means what do you want the phone to do when you disable the smart connect profiles.
e.g. If a smart connect profile enabled, those assigned items listed in "at the end" will start when you press disable.
