Have you tried to clear data for "Small App Widget"? If not, go to Settings > Apps > The tab "All" > Small App Widget > Clear data.
Restart your unit and see if the problem persist.
I tried it before, but the problem is still here.. Is there other suggestion that for me to fix the problem??
Thx
In this circumstance I would have to advise running a repair:
1. Download the PC Companion software from http://www.sonymobile.com/gb/tools/pc-companion/
and install it on your PC.
2. Install and open PC Companion then select Support Zone.
3. Phone Software Update.
4. Start.
5. Repair Phone
6. Continue
7. Accept data removal
8. Next
9. Wait for prepare
10. Select Phone
11. Follow the connection steps
Thank you very much sam. i will try it tonight
But i just wondering if i follow what you suggest is that going to delete everything in my Z1 (include photo, contact, app and all data)?? Do i need to back up my z1 before??
Cheers
Kenny
Yes and no, it does delete data however I would advise clicking on the Backup & Restore option in PC Companion and following the prompts to backup your content first to prevent this loss.
Same problem here with Xperia Z1!!!
Tried to clear data and cache but it doesn't fix...
Do you have a solution without reset the phone??
Thanks
Ambrogio Calcaterra
Milano (Italy)
@Ambros - I can really only advise following the steps provided above regarding a fix to this issue sorry.
hw about sony sending an update to fix this problem
