Sony 4.0.4 software update is not good for my phone performance speed. Always slow respond for my action. Specially using setting,installing new APk.....
Abut I found a simple solution for this. I had install ''Smart Ram Booster'' from Google app store.(Developer-Root Uninstaller)
I have enable it settings,Auto boot Settings,Boost interval setting for 1 minutes & it completely work brilliantly. Now I am not facing any system slow.
Working like a charm. If u have face this problem a lot please try this.
I had thinking this will be a solution for less memory,low CPU performance in xperia 2011 who running on 4.0.4.
Ohh!I I had allready forget to say this app will use17Mb from ur ram. But it will do the all thing for the best performance.
Xperia mini pro(sk17i) owner.
Sorry for my bad English.
Thinking this will be helpful!
Only want to help for i had face a lot.
Message was edited by: [email protected]
Thanks for the advise. When I ready your post I immediately search this app on google, but then I found this thread also... http://talk.sonymobile.com/message/223504
Thanks Menandro! But I like to use this App! Because i am facing a lot bad performance.(compare workin with GB) If found a better solution please post! Not care about drain more battery. Always drain battery copmare with GB. Anyway Thanks!
You're welcome.
Hi! Did u found a better solution?
Not yet, mmm, how quick are you to follow up :smileygrin:
Let us consult with our Sony team.....
