Are you talking about MHL cable? I am not that experienced in this area,but I have heard about it.
Hi, as Alexdon says these work a treat.......The Kit MHL-ADNK Micro USB to HDMI MHL Adapter for Mobile Devices enables you to convert your phone's micro USB port to HDMI, opening up high-definition sharing and viewing options to you.
Small becomes large
With this slimline MHL (Mobile High-Definition Link) adapter, you'll be able to transform the micro USB port on your phone or compatible mobile device to HDMI, allowing you to connect it to your HD TV.
Strong signal support
Since the MHL standard can support up to 1080p high-definition (HD) video and digital audio, the MHL-ADN-K Micro USB to HDMI Adapter is your ticket to enjoying web content, photos, videos and games from your phone or mobile device in outstanding quality on a large TV screen.
The perfect solution for versatile and spontaneous at-home entertainment, all you need do is plug the output from your device into the adapter and connect the setup to your television's HDMI input.
You'll need to use a micro USB charger for the adapter to work, and once it's up and running, you'll be able to charge your device whilst enjoying HD content.
Give yourself more entertainment options with the simple yet innovative Kit MHL-ADNK Micro USB to HDMI MHL Adapter for Mobile Devices.
