Issue: In WCDMA only/preferred mode, call/network drop frequently
Current Android version: 2.3.4
Best solution provided by service centre: Switch manually between 2G(for calls) & 3G(for data)
Customer Care ticket Id: 93172166
WorkOrder No: SE312TR111983
I have been following the case with service centre & customer care since 2 weeks but have been provided a sub-standard solution as mentioned above.
Please do not mark the thread as "Assumed Answered", I ll get back asap.
Scenarios checked:
1. 3G signal receptivity in my area: Confirmed OK by operator
2. Used same SIM in another phone: Works fine on 3G
3. Used another SIM on ray: Same issue with 3G mode
i assume they did reset your phone? since when did the problem occured?
Model: Xperia Ray
Purchase: Feb., 2012
They did, but the phone still suffers call/network drops
so you had the problem since purchase? did the dropping issue persist even when using the phone outside a building?
Yes, it happens in open spaces also.
Issue has been there since purchase, but after upgrading to ICS & eventual downgrade to current 2.3.4 by service centre made the issue worse.
there are 2 possible reasons
1) poor coverage area
or
2) you need to replace your SIM card
I have checked with two major operators in India, issue is same under either scenario.
Issue is observed irrespective of the area I use the phone, rather I used the same SIM in another handset...works fine
was the other phone an smartphone? still I suggest that you get a new SIM card to narrow down the issues, also go to
settings > about phone > status > what's your signal strength
didn't the sony center thought of it as hardware prob? did you inform them again about the peristent problem?
