My Self Mehul,
I also suffer from same problem.
If this issue is general then why should company dont think about this problem?
If any body gote resolved this problem plz reply me.
And wat can we do?
Can any body guide me wat can i do? Can i go to SC?
IMIE NO:358217042627503
did you repaired and/or update your phone ? go to settings -> about phone
which android version and build number do you have?
I have update my phone as there was communicated by Sony.
Current detail:
Android Version : 2.3.4
Build Number : 4.0.2.A.0.42
did you sent it in to sony ericsson repair center?
No still not sent at SC.
But if they have no solution than? as older post says....
Wat can I do now?
i have a same problem..it always getting in to HOME without touching the fone..my phone is just 1 month old..i cannot enjoy the phone because it acts abnormal every hour..
Build Number : 4.0.2.a.0.42
I had the same problems with my unit, the options button activated by itself. Software update didn't solve the issue. I tried to loose all the screws, because they're too tight from manufacturing. To my surprise, it solved my issue.
Good luck with yours...
try to loose the screws in the back of the unit...
I had a similar issue with my Xperia Mini, it worked alright when the weather was cold, with summer setting in and ambient temperature rising, it started vibrating vigorously, pressing the menu and back buttons automatically and forcing me out of my applications.
I must agree that it is an annoying problem, I took my handset to the SE service center in Pune, India. They flashed the stock ROM and did a software update and my problem is gone now. Had to backup my contacts and apps had to be re-installed. The version number is now ending 62. The service center guys applied a software patch to recalibrate the touchscreen menu and back buttons so that they do not activate by high ambient temperature. SE makes great products but to roll out a handset with such a big glitch puts question mark on if they are testing their products correctly.
Hi
I am in the UK and have a UK model of the ST15i also with this annoying glitch.
I'm wondering if you chaps at Sony are likely to do a product recall and fix for this model and if that's likely, when?
