SE Elm internet via PC problem
HI all
I have seen other threads about this same problem, but i did everything that was writen but i still cant use net
I went to network connections/Local Area Connection/properties/advanced/internet connection sharing-enebled, i have picked "Local Area Connection 4" (my phones connection)
Clicked ok, it changed IP address to something and that should be it
But i still cant use net.
Should i create new network in menu/settings/connectivity/usb/advanced/usb data account ?
I need some help Slightly_smiling_Face
Edit: i guess that i should have an option /menu/settings/connectivity/usb/usb network/usb network type
But i dont
Anyone?
6 REPLIES 6
Can at least someone who has Elm to confirm or deny that he/she has or dont have
menu/settings/connectivity/usb/usb network/usb network type ?
Thanks
I don't have that menu option, but I could connect to the internet fine through my Elm on Windows XP and its default SE software (that appears when you connect it to the PC for the first time).
hi
i have ELM
menu>setting>connectivity>usb>advanced>internet access>via computer
you should have that.if not somthing wrong with the software.
connect to pc with usb
then share your internet
try browesing.  try that for 5 times(i dont know why but i have to try it 3 times and on the 4th it gose to internet)
i use seven but i think it is the same on XP too.
yes, i have that too (menu>setting>connectivity>usb>advanced>internet access>via computer) but i just cant use internet
my pages r keep loading until it fail
It is connected by ysb cable but my internet is wireless and it's using 5ghz
maybe that has something to do with it? (i doubt since it's connected to internet via usb and now via wifi)
Hi Everyone
I bought my ELM a couple of days back. I have active my GPRS services to use internet using my laptop too.
Finally after experimenting with the device while connecting internet via laptop. I have experienced weird situation.
The device when connected using Bluetooth make no problem connecting to the internet using my laptop. But when connected using the USB cable it sometimes do get connected but most of the time it keep on trying dialing the connection and finally fails. It is also experienced that even the device gets disconnected from the PC suite automatically. Very weird off course. Now I have experimented using my desktop too. And sorry to say the situation remain the same.
Just to make people understand the situation better I am giving approximate numerical figures.
Connecting using Bluetooth
             Unsuccessful in connecting                  5%
             Successfully connected                         95 %
             Able to use the net                                90 %
             Getting disconnected in between use       5   %
Connecting using USB Cable
             Unsuccessful in connecting                   70 %
             Successfully connected                          30 %
             Able to use the net                                  10 %
             Getting disconnected in between use      80 %
From the above data it is pretty evident that there is definitely some problem with USB connection. But having said that I must also admit, there was 100 % success in data transfer from PC to mobile using PC suite. So there is no problem in normal USB cable use. But the cable starts to behave very abnormally when tried to connect to the internet.
So I would like to conclude by saying it’s a very wired software problem. That Sony must try to address to.
Hope in the next software update for the device will rectify the problem. I am impatiently waiting to download the next software update for the new SONY ELM.
Thanking all.
Hello everyone I have a k970 phone. And I have a problem connecting to the Internet through your computer. I'll be happy to help.
A network location:
Physical Address: 02-80-37-EC-02-00
IP Address: 169.254.43.230
Subnet Mask: 255.255.0.0
Default Gateway:
DNS Server:
WINS Server:
Please Help.
[email protected]
or
[email protected]
