sd card problem
MINA51
sd card problem
Each time i connect or disconnect the handsfree speaker or the usb whether to charge the phone or to connet it to pc the sd card dismounts automatically and i get an error message saying "sd card unexpecteadly removed please dismount before removing" what should i do
13 REPLIES 13
Thommo
Genius
Have you changed any settings regarding USB connection?
MINA51
Nop i didn't i 've just bought the device a couple of days agk
Thommo
Genius
You must have an app installed that when connected to a USB device like a Pc it is set to dismount the SD card and mount it as an SD card on your Pc - I remember Winamp did this
MINA51
Um i dont think so cause as i said the phone is like stock
Thommo
Genius
Well if you've installed nothing then perform a system repair
Performing a system repair using Pc Companion will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
MINA51
will it erases anything from my phone
Thommo
Genius
Yes but you said it was like stock so nothing lost
MINA51
Yes but what about contacts and call logs
Thommo
Genius
Back them up
