that seems like a hardware issue, you could repair it with PCC if you want to narrow down the problem but, you should contact your Local support to get your phone inspected.
If it was taken from -25 celsius outside room, to 25 celsius in room, then its 50 degrees difference, in that condition even if its only air inside your phone, it turns into condensation water.
I would turn off the phone open seals usb, sim, memory card, take all out, and use hair dryer ON BACK NOT ON SCREEN. For minute, wait to cool down, then repeat.
